200 miles on a tank?
I wanted to see if it will make a differance, plus thought the 93 would give me some mo powa :D
Do most guys use 87?
It won't make a difference in power for at least a tank or two so the computer adjusts timing accordingly, even then you won't notice it. Unless its pinging/knocking for some reason (which should be solved in a way other than putting premium gas because something is obviously wrong). I used to use 93, and then realized that it didnt make two ****s of a difference if used 87 :D
Unless you get a blower, stick with 87.
I'm getting crappy milage too. Like 14 MPG city. I even took off my roof rack and haven't noticed much of a change. I'm going to check my tire pressure tonight.
You might want to do that too. It won't have a big effect, but it is important to keep them at a good PSI.
I had mine a 36 pounds for a while, didn't notice a big difference over 32, except terrible ride quality. :D
My light comes on right around 200 usually. If I fill up then It'll take 12-13 gallons. I know I can stretch it out to 250 miles or more if I need to, but don't feel like taking the chance of running dry. Now that measurement is off of the odometer so I know I'm getting a real 230ish before the light. With the bumpers, tires, and armor, I guess I'm sastisfied with that milage.
My light comes on right around 200 usually. If I fill up then It'll take 12-13 gallons. I know I can stretch it out to 250 miles or more if I need to, but don't feel like taking the chance of running dry. With the bumpers, tires, and armor, I guess I'm sastisfied with that milage.
Ya looking at your tire size and your lift that is good milage. nice mod list bro
My 97 auto 4cyl just hit 170k and still gets 290-310 miles to a tank everytime! All through the washington mountain winter, while buying the cheapest gas I can, driving in traffic, with a pretty heavy foot (says my wife). Bought it at 105k, kept up on maintenence (always synthetic fluids amd iridium plugs)
I usually get ~200 miles per tank. Coming from a 94 suburban, I wasn't complaining. The CEL came on today and when I took it to get the code pulled it came back P0420. Homegirl at O'Reilly said it was the O2 sensor. I don't know much about those things but I know they're pricey. I'm not too sure if it's definitely the O2 sensor (I've read some posts that say it could be the cat). I'm pushing 170k so I ordered some new plugs and wires – Denso/NGK respectively. Once I get those in I'll see if the CEL is still on. However the other day I did notice the Runner's exhaust was quite overbearing. On another note, I wish the Runners had bigger tanks (or could at least be modded with them). My 'burban had a 42 gallon tank. I want that in my Runner!
I've know of people that have put in an F-150 gas tank(forget what gen) in the spare tire area, that at least doubles the capacity. So they are mod-a-ble, but I'd venture to guess it involves some decent fabbing work though...
yes thats what i was hoping for when I bought the truck, hopefully I can see numbers like that soon.
Im at 122k and just bought the truck a few weeks back.
182k here. Getting about 16 city, 20 hwy.
2.7 liter, 32" AT's, 4.56 gears, K&N intake to let it breathe, headers, cat, and catback to let it flow nicely, hitting 290-320 a tank.
Mixed city/highway. When put strictly on highway though, I will be honest, I usually travel at 85mph... probably should try 65 on a trip and see the MPG.
Old catalytic converter was clogged, the 2.5" cat did wonders. Gears took me from 14mpg avg to 17 avg.
I noticed a little when I changed the O2 sensors, too.
I dont want to get into changing gears, but I should look into changing the cat maybe.
The truck does have a strong emissions odder to it on startup if your standing outside the truck . ( But I figured it was 12yrs old , I think its normal ?)
Feelig pretty good after reading these posts.
191k, 3.4, winter gas, 50/50 Hwy/City, 80/20 4wd/2wd use= 220-245 per tank.
