2000 4runner overheating?
MILLERT
I just (3 weeks ago) got my 2000 4runner serviced, and was today sitting in a drive thru, looked down & meter was at RED! 145000 miles. Took it back to them, they checked, filled "reservoir" and said to watch it. "Smelled coolant" they said. What does this mean?
If they smelled coolant that would be a normal smell coming from the radiator or radiator reservoir since that's where coolant goes! If they mean they smell coolant from the tail pipe that would mean a blown head gasket. I would be very surprised if your head gasket was blown though. Watch your coolant level and if it goes down and you can't find any leaks, you could have a blown head gasket. Look for a milky color in your oil and look for white smoke coming out of the tail pipe. Track your gas mileage also for a couple of tanks and see if you're getting at least 16-17 mpg. I usually get almost 19 but at times get as low as 16. If you can, you should flush your cooling system. I had overheating issues when I first got my 4Runner and it ended up being the radiator. I tried flushing it which helped temporarily but after a while the radiator clogged up again. My guess is the previous owners never ever flushed it when they were supposed to.
I've got a 99 sr5 4wd and I am getting the code po171 (system too lean). There are no leaks from what I can tell. If I am getting ready to drive across the country should I replace the mass airflow sensor to keep the engine from overheating?
Soo are you over heating as of right now? Also i would clean your maf and clear you code before going out and buying a new maf.
Laredotx
