2000 limited, trouble engaging 4wd with button
Godog45
Hi, i have year 2000 ,limited ,having trouble with the button on the 4W lever. that engages to H4 {Unlocked ] i have 239K on the car and i am the second owner.
it recently having difficulty engaging H4 with the button on pavement unless you stop and put it in reverse it will not engage . when the light blinks ,the steering wheel will feel heavy and car pulls left. you must stop and put car in reverse .then it will work normal ,also sometimes will hear a thud
the H4L lever {IN locked position}
works fine . i only have trouble with the button, with the unlocked position
any suggestions whats wrong and what it needs to work properly again?
Fix
I had a similar issue and replacing the transfer case fluid was the fix. Some people forget to change it and when it is old all type of engagement issues can happen
