dawudih
I just bought a 2000 Sport 2wd with 165k & had a few questions...
1. I did a drain & fill on the transmission & only got about 4 quarts out; does that sound about right? I used autoxxxx's house brand, is that ok?
2. The door locks don't always unlock when I take the keys out of the ignition, it seems like a random event.
3. The drivers door lock does not unlock with the fob, I have to use the key hole.
4. The rear differential bolts seem like the're welded on, what's the drain capacity.
5. The coolant is pink, can I get compatable non-pink coolant from autoxxx or do I have to use Toyotas coolant?
6. $6000, is that the going rate? 1 Owner with a stack of maintenance records.
7. I looked & could not find a way to replace the power steering fluid "easily".
8. :thanks:
8. :thanks:
