2001 Toyota 4Runner 4x4 in NW Arkansas, Siloam Springs 5900.00
I'm selling a 2001 Toyota 4Runner 4x4 SR5. It has 216k miles and runs and drives great. It has normal nicks and dings for a vehicle of its age. the transmission and transfer case work perfect The only reason I'm selling is that I need something more stock for my family right now
It has a 3" lift with 285-75-16 All Terrains. It has a nice stereo with CD that has the Bluetooth so you can run your phone thru it. Front windows were tinted, Euro Tail lights, Cold AC and hot HEAT. The lift and tires are approximately 2 years old. New tie rod ends were replaced when the lift was installed. Power windows and door lock and keyless entry (w1 rem).
The 4x4 works perfect and has the center transfer case lock. Some of the pictures without the running boards are the older ones. I have the running boards on it as of now. I have done the VSC TRAC and DRL mod
The BAD:
1. Had a issue with the motor and had to put in a used one about 3 months ago. Still cant figure out what went wrong with the old motor.
2. Its going to need an O2 senor. The engine light comes on from time to time and I was told it was that.
3. CV boots need replaced. I put on a diff drop kit but they were already damaged. I have a full set of front shafts that have good boots but no time to put them on.
Im asking 5900.00 And im located in NW Arkansas. Im about 5 minutes to Oklahoma and less than an hour to Missouri Please call or text me if you have any more questions (faster response).
