2002 4Runner - ABS, Trac, Brake & Check Engine Lights all on, High Pitch Alarm
lanbe104
Hello Everyone,
Please Help!!!
My 2002 4 Runner has all of the warning lights on, a very high pitched Alarm sound inside the vehicle and my brake pedal is very hard to push, as though the power brake motor has failed.
Where do you recommend that I start?
Thank you!
Hello Everyone,
Please Help!!!
Thank you!
Could be as simple as a bad ground or battery terminals or potentially the brake booster or brake hydro motor.
edit; TRAC VSC and ABS lights on
Hello Everyone,
Please Help!!!
Thank you!
DONT DRIVE! Your brakes will fail very soon, I had this happen! The issue is you blew your 60 amp ABS 1 fuse and possibly the ABS 2 fuse. It's a simple fix but can be dangerous if you drive like this.
ghengiskhan
