2003 engine removal 4.7
calvinv8sr5
Need to know if anyone's done it, I might have to change my motor out and can't find any how to's, send me links, give me pointers if you have any, all will be much appreciated. I've pulled motors in older vehicles before, never a toyota, or a 4.7, thanks in advance
live action!!
live action!!
Dude!!! What happened to your motor?
Other day started drinking oil and smoking, it hasn't ra right since I bought it, no one ever heard of this motor rings going bad.. of course mine does... I tracked and haggled my ass off to find a 130k motor for 650 plus 100 core that I'll get back when I give them my old motor (still undecided if I'm gonna give them my motor or sell it for parts ) my motor has skipped on cylinder 7 and 8 since I bought it. But either this weekend or next I'll change the motor out
live action!!
the repair manual has a pretty in depth guide, just go under the car and open the hood and look around for connections, the hardest part will probably be keeping track of bolts, how much will the new engine cost?
I talked a big junk yard near atl down from 800 to 650, then when I got there they were suprised that I showed up so they knocked off 50 more. 3k warranty then 100$ for core charge. So I made out like a bandit. Gonna change it Friday and Saturday might lay it over to sunday also depending on how hot it is. I've been working on a 1905 house gutting it in the 98 degree weather in Georgia. Hopefully it goes well with minimal broken shit
live action!!
live action!!
I have done it. I had to make a bracket and make some bolts adapters so I didn't have to pull the intake. I also pulled the transmission with the engine. This is also a good time to do the timing belt!
If you keep the engine or can get a part, I need the water pump/fan drive bracket.
sub'd for interests and spare parts... I need an oil pan for an 03 V8... maybe you can sell enough parts off the old engine to make up your core charge and pass on some awesome prices?
Ok send me pics of what yall need, why didn't you use the hooks on the sides of the intake to pull the motor, and why a so did you pull the tranny
live action!!
live action!!
I bought the SR5 (#2) with a bad motor, replaced it with the motor and transmission from Sport (#1) that I knew the complete history of since I bought it new.
The hooks will not allow you stab the tail of the transmission under the firewall while clearing the radiator support. They are used on the assembly line for installing the motor/trans to the frame without any body around it, guessing here. Using the old chain and hooks for the engine might work, but you will have very little adjustment to align the torque converter and the flywheel bolts. The picture shows the homemade balancer that will allow the engine/trans to almost stand on it's tail.
I need this piece and can ship back the broken piece for your core! Notice the place where the upper belt pulley bolts is broken off (upper left)
Ok shoot me a message Friday and I'll take it off and set it aside
live action!!
Alright the motor is out and ready to part out. By the way the intake valves look the heads are good, I think some of the rings are bad atleast one so that's what I know about the bottom end. I'll start a for sale thread
live action!!
Do you need the entire oil pan or the bottom small pan
live action!!
