2004 4 Runner wheel size HELP
I ordered new after market wheels for my 2004 4 Runner Limited, same size wheels that came from the factory. They did not fit because of the backspacing & offset. No where can I find what the backspacing & offset measurements should be. I even e-mailed Toyota and they claim that these numbers are not published anywhere. Basically, they want you to keep the same wheels on the truck. I don't want to change the size or raise the truck or change the wheel rotor. I just want new wheels. Can anyone help me with the backspacing & offset numbers?
Our rims are +30 offset. So, if you want them to sit out farther you would go closer or past zero to a negative number. For instance I am going to get 17x9 with a 0mm offset.
Things to remember, if you change the width of the rim, stock is 7.5", it changes the numbers. There are sites that you can visually compare widths, tires size, and offsets with stock sizes.
What size did you order???
I'm not sure what style your leaning towards, but check the FJ forums. I just picked up a set of 8 hole FJ wheels with 15 mm offset. They're pretty nice and you can usually pick them up for a decent price of that crew over there.
H.Sikina
