2004 front wheel bearing replacement
jacktahoe
My front wheel bearing went out on my 2004 4Runner
I was quoted 600 dollars for replacement.
How hard is it to replace by yourself?
Not too Hard...
With various searches you will find two paths...you can buy a bolt on unit complete from ebay from here:
2003 4Runner 2004 2009 4Runner Wheel Hub Assembly Front Wheel Bearing Assembly | eBay
or
2003 Toyota 4Runner 2004 2009 4Runner Complete Front Wheel Hub Bearing Assembly | eBay
The difference in these products is the Bearing brand name and country of MFG.
the OTHER ROUTE...will disable the vehicle for a longer period of time, but may be cheaper with you figuring out which parts and finding a shop to press out the old and in the new bearing parts.
I went for the bolt on method. Easy. Need 35mm socket and cheater bar for the axle nut. The write ups are as far as your search bar.
Good Luck.
Kevin
lindwlson982
