2004 front wheel bearing replacement
jacktahoe
My front wheel bearing went out on my 2004 4Runner
I was quoted 600 dollars for replacement.
How hard is it to replace by yourself?
Not too Hard...
With various searches you will find two paths...you can buy a bolt on unit complete from ebay from here:
2003 4Runner 2004 2009 4Runner Wheel Hub Assembly Front Wheel Bearing Assembly | eBay
or
2003 Toyota 4Runner 2004 2009 4Runner Complete Front Wheel Hub Bearing Assembly | eBay
The difference in these products is the Bearing brand name and country of MFG.
the OTHER ROUTE...will disable the vehicle for a longer period of time, but may be cheaper with you figuring out which parts and finding a shop to press out the old and in the new bearing parts.
I went for the bolt on method. Easy. Need 35mm socket and cheater bar for the axle nut. The write ups are as far as your search bar.
Good Luck.
Kevin
