2004 sport - problems
bk4runner
I have a 2004 sport with 131000 miles on it and the Brake light, traction control lights and ABS lights are lit constantly. any help would be appreciated
Are you brakes functioning properly? Take it to the dealer ASAP; brakes and ABS are not something I'd mess with.
The typical array of X-mas lights are not the ones you have noted.
Check your ABS wires that run from the engine bay across to the upper control arms and down the spindles to the sensors. They can be stretched and break inside the plastic coating resuklting in no or sporadic continuity.
Have you done any suspension mods?
i have not done any modifications. i took it to the dealer and they ran the code for a rear speed sensor gone bad on the driver side rear. i had that replaced at my normal garage for alot cheaper lol. i drove it home with no lights coming on until i got home . i took it back to garage and they pulled the bearing where the sensor is and cleaned it . same thing i drove it home no lights until i was almost home again lol. is it possible that i have a seal gone bad somewhere in the rear that keeps gunking up my sensor?
Motomoto227
