PolkManiac
I'll try my best to explain. I have a 2004 V6 4Runner, been a great vehicle so far with no real problems. However, I've had the following issue for a few months now.
After driving for a while, I get a whining sound from the engine compartment. It only occurs when we put the car in park.
I can pull into my garage, keep my foot on the brake and keep it in drive or reverse and it doesn't make the noise. Then I put it in park, and the noise appears, then I can put my foot back on the brake and put it in gear again and the noise goes away. From what I can tell, it is 100% dependent on the car NOT being in park.
This problem is intermittent, but fairly persistent.
I have another symptom that I believe to be linked. On occasion (though much less often) my AC goes out. I get the blinking AC light on the inside, and no cold air. I can turn the AC off and on a few times and it'll kick back on. I believe the blinking light indicates that the AC motor is not being turned - it's the same light that has appeared before when I drive through a very large pool of water and the belt gets too wet.
Any thoughts? I just had the belt replaced, but that did not correct the issue (it had no effect on the issue, no better or worse since the install).
