[2004 v6 sports] Front brake rotor and pad.
rshin82
I have 06 v6 SE[8,3000]. I had this front break problem for a while.
I think it's time to change whole new rotor and break pad.
It vibrates a lot! I heard there were like ABS issue, is that true?
Where should I order the parts? If you guys know~ please tell me.
Thanks a lot!
I plan on using OEM pads. But others have used EBC, Napa, etc.
You can try partznet.com for OEM parts.
It vibrates a lot! I heard there were like ABS issue, is that true? Not that I know of... There is a sticky/stuck caliper piston issue that affects some 4th gen front caliper issues.
Where should I order the parts? If you guys know~ please tell me. Partznet works well for OE stuff, I like Rockauto.com for non-OE. If you need a caliper a rebuilt from Rockauto or Napa will serve you well. Napa "premium grade" rotors are always a good choice too.
Thanks a lot!
:cheers:
I did a front brake job on my 03 sport some time ago (freezing caliper problem). I put calipers from NAPA (they were 180 against 400 or 600 toyota's) but I put OME rotors and pads. Imho OME parts work the best but sometimes they are too expensive.
044runner4
