How to replace Oxygen Sensor for 4Runner 2012 Trail Edition - Bank 2 Sensor 1
Hi,
I would like to help if someone needs to replace Oxygen Sensor for 4Runner 2012 4.0L V6 on the Bank 2 Sensor 1 or so called the Driver Side A/F Sensor.
I did it by myself on the weekend, and here is the steps that how I did it with a very simple tools to do the job.
What happened is my Check Engine and its Anti-Roll lights were on recently after 95K miles on its odometer, and only after its part warranty expired at 80K miles. How irony is it?
Used the OBD2 scanner to check for its codes. As shown P10051 and P22240 where the former - Oxygen Sensor Heater Control Circuit Low and the latter - Oxygen Sensor Positive Current Control Circuit Open or Shorted, located on Bank 2 Sensor 1 - the driver side in front of catalytic converter.
Removed the sensor plug, with a voltmeter to check for the resistance between pin 1&2, and I found that it was none so meaning that the heater circuit already burned out or open.
Placed order for the part - Denso 234-9101 from Rockauto.com and now is ready to install it.
See the pictures and its itinerary steps had taken to replace the sensor.
Some extra things needed to mention at here:
1. Use the 22mm Oxygen Sensor socket which is available at any auto parts store.
2. Do not use one piece 18 or 30" long extension bars due to its rigid and very difficult to insert behind the engine against its body frame. I used several shorten ones and taped it to hold down together for its flexibility. Insert the O2 sensor socket into the sensor first and then extension bar from bottom to the top. Do not go from top to bottom. Align socket and extension bar then hold on its length to pull down to lock it.
3. Spray WD40 into the sensor threads to get loose some rusty stuffs.
4. Start to turn CCW from the top as shown in pictures to remove the sensor.
Hope that it will help.
Cheers.
