2011 sr5 popping sound with wheel turn
Duke562
So my sr5 started making this popping sound at slow speeds when turning the wheel like something was settling into position . It is not the tie rods, sway bar end links or suspension had a 4 hour inspection today at a shop and still no luck .. Anyone have these issues or have any ideas
Mine does it left side anytime slow speed turning left mostly . I think it's the sway bar needing the relocate piece from toytec or icon
Any idea what the issue is . I installed the toytec front sway bar spacer kit to see if it was that ... Still makes the noise
Off the top of my head I can't remember if the sway bar endlinks (non-kdss) attach to the control arm or the spindle. If they connect to the spindle I'd look at those as your culprit. I've dealt with a couple cars that had ball joint end links that had similar issues.
