2012 "modified" Trail Conversion Question
DesertDog
Member
I have a blizzard pearl 2012 SR5. I recently ordered shorockwork sliders and need to replace the rockers anyway, so I was thinking of just doing the whole trail conversion.
I've read through the great threads of Harper7, Jangoforhire, and Hbryanlopez about the trail conversion. Their threads are all all very helpful and their trucks turned out wonderfully.:guitar2:
However, in order to add a slight twist to the conversion, I was thinking of color coding all the parts (bumpers, flare, rockers) blizzard pearl. In other words, much closer to the 2010 Sr5 2wd and Canadian SR5 version. I've seen lots of little hints in my searches that the 2010 SR5 2wd front and rear bumper are identical to the Trail (with one exception: a comparison of the Toyota configurator images in 2010, which I don't totally trust compared to some of the actual images and part diagrams I've looked over). If so, I presume the approach and departures angles are equivalent to the Trail bumpers. If I'm going to spend all the money, I want to get the approach and departure angles correct.
Since I'm going to have the entire bumpers painted blizzard pearl, and the SR5 2wd front and rear bumpers were designed to be color coded with the body, that seems like the path I should take. If I could use those bumpers (assuming they have same approach and departure angles) would save money on the front and rear valances of the trail version (though I have not checked on painting costs, but I presume it would be an insignificant price difference between partially painting the bumpers and fully painting). I also want to keep my parking sensors and the SR5 bumper was designed for them (though I imagine I could drill hole in the Trail bumper to achieve the same thing). Has anyone ever been able to confirm that the bumpers are the same?
I don't think any bumper comes pre painted no matter if Trail or the 4 cylinder 2010 2wd SR5. I may be mistaken though.
You are correct. I would need to have all the parts, including the bumpers, painted blizzard pearl. But that is true of the Trail bumpers as well.
I must be missing your question then.
That's probably because my post got overly wordy. Has anyone every confirmed that with the exception of not having trail valances, the SR5 2wd and Trail bumpers are identical? I guess the real question is simply whether I will reap the same approach/departure angle improvements by going with the SR5 2wd bumpers as compared to the Trail bumpers during the conversion?
It's a lot of money to spend to do the conversion and I hope to reap some approach/departure angle benefits other than the mostly cosmetic change.
I think the Canadian Sr5 used the TE bumper covers as well as the 2010 4 cylinder 2WD SR5. The vast majority of the SR5's were 6 cylinder and had the standard 4WD SR5 covers. You will gain a bit of approach and departure angles with the TE covers. Hope this helps.
Talyn
