GrantK
A couple of possible issues that should be checked.
*) Warped rotor - This is usually worse when braking and can be felt through the pedal.
*) Wheel (rim) run out. This checks the rim for both how close to perfectly round it is and how out-of-true (side to side variance) it has.
*) Tire placement on rim. Because of TPMS, the tires need to be placed on the rims correctly (I don't remember the mechanics name for this). Many tires have a green or yellow dot on the inside that needs to be positioned with the valve.
If there is a run out issue new tires and balancing will get you no where.
I have a 12 TE as well with Konig Countersteer X rims and Nitto Trail Grappler MT (285/70-17) and the run out was almost perfect and the balancing is great, no vibration at all so there is no reason you shouldn't be able to get the same with your setup.
