2014-2016 behind grill light bar mounts.
Will this work on a TuRD Pro? I think the front grill is a little different?
I would assume they'll work. The lower grill on the Pro looks the same as my TE. Can anybody confirm the aluminum X-cross member is the same for both models?
Just shipped 5 sets out, another batch will be shipped later this week.
Emails sent with tracking info :thumb3:.
Any update on if this will allow a 30" to fit in there? I have a 30" awaiting install either with these mounts (pending answer) or the redneck way.
That's one pretty piece of hardware there. I have to say all that welding is top notch and looks really great. Though you could probably reduce your manufacturing costs by taking out a lot of the welding.
Where in NC are you located. I have a set that haven't been mounted yet if you want to test fit.
Thanks for the kind words, much appreciated! Where would you eliminate welding? Personally i think these parts look incomplete unless fully welded. I also have high standards when it comes to welding and fabrication, quality over rules everything on my builds.
Just to be clear on the figment topic. These mounts were designed for use of a 20" bar. The largest bar you can squeeze in there would be a 24", there is clearance but I have not physically installed these using anything but a 20" bar.
These mounts would also work great if you wanted to mount acouple single LED pods behind the grill.
Honestly If I were building a one off bracket for myself I would do it just like you have done! Just thought I'd throw out the idea since you seemed like you were starting to produce them in number.
1. If you wanted to setup a couple of LED pods, would't you need 1 set per pod?
2. I was actually thinking of a heretic studios light. They are technically 11'/section, so a 20" would be a 22"... would even that be tight??
No, 1 mount per pod. Small pods usually have a bottom mounting point with 1 single bolt hole.
A 22" bar will fit no problem.
Mike Sargent
