2014-2016 behind grill light bar mounts.
Hmm, wonder if one of these would hold a Light Cannon sideways and have clearance...
Great work--told you there would people throwing money at you!
Haha thank you. How big is the light cannon? These will work awesome for acouple pods behind the grill, is that What your thinking?
4.5" 25 Watt LED Light Cannon - Vision X Lighting
4.5" diameter for this model. I would think placing 3-4 across the front. Here's an example of 5 across the front with [MENTION=114472]TRD Pro[/MENTION]'s mounting solution shown:
http://www.toyota-4runner.org/5th-gen-t4rs/180431-vision-x-light-cannons-my-trd-pro.html
Most LED pods are around 3" square, though, so your bracket might offset the Light Cannon too high in the grill?
These brackets have a mounting hole that is centered in the lower grill, so if you take that light cannon rotate it 90* it will still be centered in the grill.
Got notification that my mounts were delivered home today. Looking forward to checking them out tonight. Here is the bar I am considering mounting up with them.
https://www.auxbeam.com/77718117
I really like the ability to just turn the amber zones or white zones on if needed.
My 42" bar on the windshield is made by Auxbeam and it has been phenomenal. I've also installed their lights on my Polaris and a golf cart with great results. Exceptional quality for the prices.
0m
pm send
i have a undercoverhwms hidden winch system , will it interfere with the install?
currentlly i mounted my bar with wood blocks mounted from top brace and with the Warn, im a little limited in space back there as you can see
thank
-pete
From your picture you posted I don't think they will work...if you take a look your light bar sits a few inches higher than these mounts put the light bar as on his white 4runner in the page 1 image...unless is have some room to lower your current position.
I'd have to agree, looks like the winch will restrict him from using these mounts.
That's a nice looking bar!
bummmer, thnks for replies guys, guess ill have to pass on the fine looking mount
-pete
If you don't mind the drive, you could check mine out when they arrive. I would be interested to see if they work on your truck because I would like to have the same winch set up.
Update us if you guys do this because I was thinking about that winch in the future.
I think if you relocate the control box you can afford yourself more vertical space if needed, though it almost looks like you might have an xd series winch meaning you can't do that. In any case, my larger concern would be weather you have enough space on the mount to actually mount the brackets.
thats awesome! you only like a hour away, throw me a shout once you got it install and ill drive over!
-pete
cant, you are correct i got the XD model, ill take a close up pic later this afternoon
-pete
