2014 Headlight Bulbs
Generally, it's good to at least check the manual. Things like bulb size, fluids, wiper blade sizes... are going to be in there somewhere. It may not always be in a location that is easily found, but it will be there.
Lots of users register just to ask a question to save themselves the 2 minutes it would take to look for the answer. It adds up fast. I find responses to be much more positive to posts that are along the lines of "I tried this and I looked for an answer but I still need some advice..."
To your point, I researched via google, searched the sight, but found no information. Thus, I posted a question. Next time I will be sure to use that as a qualifier to avoid the needless posts. Thanks for the pointer re: the manual. Learn something new every day
I just did a pnp kit in my stock projectors on a 2014 trail. The results were quite good with no noticeable squirrel spotters. I used XB35 H11 bulbs and fully potted Denso ballasts from TRS. FYI, the most recent batch of Morimoto ballasts have a problem with the ignitors in them. TRS has newly designed ballasts with larger ignitors on order and they are supposed to arrive December 10. So, either order a set of potted Denso ballasts (OEM) or wait until December 10 to get the newly designed Morimoto ballasts.
BTLAW, I sent you a PM, hope to talk soon
Seriously? No before and afters? :doh:
Was a fair question to ask and good thread to start. Lots of questions / answers should come of it - but anyone who has photo evidence better darn well post them or Philsey is going to pull the last remnants of his hair out.
Hi, just purchased a 2014 Limited 4x4 and I'm new to the forum. I am wanting to do an HID conversion, but I am not sure what bulb types come in the T4R
Does anyone know what type of bulb the '14 limiteds take for the headlights and fog lights?
TIA
Nick
To help you out: Low beams - H11
High beams - 9005
Fog lights - H16 (19W version of an H11)
DSC_0005.jpg~original
DSC_0004.jpg~original
DSC_0001.jpg~original
Picture of Output
Here is a picture of the output with Morimoto XB35 bulbs in 2014 stock projectors. Granted it is nowhere near as good as my wife's 2013 RX HIDs, it is still a huge improvement over stock. While there is no noticeable squirrel spotters, there does seem to be some very very faint glare above the cutoff.
DSC_0003.jpg~original
That looks much better than throwing HIDs into a non-projector at least. I retrofitted on my '10 and love them. Should have come from the factory with HIDs.
What is the kelvin rating of your XB35 bulbs? They look quite yellow in the pic to be HID's...thanks.
Thanks for posting a pic, BTLAW.
Just so I understand, I can achieve this look by simply swapping the lamps in my 2014? No other parts necessary?
That's correct. It's a quality PnP setup in stock projectors.
Not exactly correct. [MENTION=102046]Soundofmind[/MENTION] , if you'll check you'll find that HID bulbs require a "kit". This will consist of bulbs, ballasts, a wiring harness, and a relay. It is not rocket science, but neither is it as simple as just a bulb swap.
Do yourself a favor and buy quality components, suggest TRS.
Buyer's Guide here: http://www.theretrofitsource.com/trs_tech.php
I met up with BTLAW tonight to see what the light output of the TRS pnp kit vs. the stock output. My understanding is that BTLAW (left) uses a 35w bulb @ 4300 Kelvin with the Denso ballast. Pretty dramatic difference...
Laredotx
