2014 LED tail lights
Bump, I want to know as well. Any of you 2014 guys mind popping off that rear plastic piece for a min & snapping a pic of the connector, takes 5 mins, I just replaced my passenger tail.
Didn't [MENTION=51030]joneseyyy[/MENTION] and crew pop the panels off of the 2014 at the FJ Summit?
They said it wouldn't be plug and play.
Here's some Antman-style photos from you. Granted, these trucks may have been pre-production?
Ok, here is the back of the DR side tail lamp in my 2010 Trail.
The plug looks identical and the colours are the same. With no body changes in the rear, I'd bet dollars to doughnuts that it will swap no problem.
IMG_1334_zps0a0ca043.jpg~original
IMG_1332_zpse3e7cd0b.jpg~original
I know that on the 2010-2013 there was a difference between the SR5/Limited and the Trail tail lamps. I wonder if Toyota has done the same with the 2014
the stealer i talked to had three different part numbers on his parts list so that leads me to think that there are differences......But i cant find a visible difference in any pictures.
I run a repair shop and I deal alot with Toyota. I decided to call the parts guy I always deal with and I spoke to him about the tail lamps. At first, when he looked it up he said that he would need a vin since all 3 levels of the 4R use different tail lamps. But then he looked further and found that all 3 supersede into one # for the L and one # for the R. The part #'s are as follows:
Right= 81551-35400
Left= 81561-35390
List price is $318.12 each and my price is $270.42 each.
Right= 81551-35400
Left= 81561-35390
Might be contacting you soon!
Right= 81551-35400
Left= 81561-35390
If you wouldn't mind, would you have your parts guy check on the 2014 rocker panel. It appears that the SR5 and Trail are the same and the limited is different. The guy I was talking too quoted me what I think is the wrong price which leads me to believe it's the wrong part. I am looking for the 2014 rocker panel trim for an SR5. (Wanting to put '14 trim on '13 SR5)
Much appreciated.
Right= 81551-35400
Left= 81561-35390
will they fit though?!
Second question, where in SO CAL? Most of we own are toyotas, I would love someone who knows what they are doing and has fair prices :)
Right= 81551-35400
Left= 81561-35390
I am also willing to buy this if you can make sure they will be plug and play for the 10' to 13 4runners.
Much appreciated.
Ask and you shall receive....Okay, heres the deal. According to my guy, there is a "rocker panel" and a "rocker moulding" I'm not sure what you want or need but here are the part #'s and prices based on a vin # from a '14 SR5. The part #'s and prices are as follows:
Right side rocker panel= 61311-35020 $226.96
Left side rocker panel= 61312-35020 $226.96
Right side rocker moulding= 75805-35130 $234.66
Left side rocker moulding= 75806-35100 $234.66
According to my guy, he said that they "should" fit. Unfortunately he is not 100% sure. Just for kicks, I searched those part #'s on the internet and found a couple sources that sell them for less. Might be worth it to see what their return policies are like in case they don't fit.
I'm in Burbank. Our shop has been family owned for 40 years and we're AAA approved. We employ an ASE master tech. I see you're in OC which is a little far. Our pricing is based on the fact that we have high standards, offer a 2yr/24k warranty and we're not a bunch of grease monkeys.
That middle plug does look identical but what about the other two in the 14' tail light pics that also connect to the lights.
That middle connector might be the same because of in the description of them for 14' "New LED tail lamps (filament turn signals; LED side light)"......the turn and brake lights take the same filament bulbs as ours do for the middle connector.We don't have the other 2 wired connectors on a 10-13' like it appears they do for the LED lights.
