2014 SR5 limp mode activated following 'routine' oil change
Jhunt
So desperate here, and this is my third attempt to put this together in a simple, but clear way.
Dealership did oil change. Vehicle ran fine for several weeks, then entered limp mode. After 2 years of stalling (i know, trust me, im a doormat, its not a secret) from the dealership, i decided to run the list of possible reasons for the limp mode, and checked my fluids.
I know this will sound BS, if someone told me this, i would call bull, but i nearly filled a 5 gallon bucket with oil when i drained it. It took 4, 5qt jugs to bottle it up after for my clean up.
And when i checked my transmission, i found 3 things that still make me sweat. My drain plug was stripped, with fresh metal exposed, i only had a few ounces at most of fluid in it, and most importantly, the cover over my oil drain was not only still in place, but the bolts holding it, were rusted so badly, i had to cut the skid plate off after every single bolt snapped while trying to get them off by hand.
What i suspect is, one of their younger guys drained the trans, instead of the oil, and just went wild on filling it back up, or wasnt paying attention or something.
After doing full fluid and filter changes, checking for metal shavings or fragments, i found nothing to indicate physical damage to either engine or transmission.
But she still goes straight to limp mode when turned on, and after the initial tow home, i lost 'drive' entirely, i can only reverse, however, after sticking an endo camera in through the drain, i found no signs of damage to the physical gears that were visible.
I owe a bit more on it, but i want to know if this is even worth trying to fix.
And every mechanic i talk to, says its 'probably' electrical, but no codes are being thrown, and i just had major electrical work after an insurance claim the previous summer, including a new ECM (rear hatch was smashed in a parking lot, and a faulty replacement window motor caused a catastrophic short, per the mechanic that AAA told me to use).
I would prefer to fix it, but if its going to cost me more to fix it, than it would to buy a new vehicle, then it just isnt worth the money or effort.
If you are anywhere near Chicago area, I'd say give this shop a try. He runs his own Youtube channel and has a legit shop for Toyotas.
AI answer tad more detail of possible issues.
1. Why You Lost "Drive" (Transmission Issues)
An automatic transmission relies on fluid not just for lubrication, but as hydraulic pressure to clamp clutch packs together. Even if the metal gears look fine through a camera, running the transmission with only a few ounces of fluid causes severe, hidden damage:
  • Burned Forward Clutch Packs: Reverse typically uses a separate, heavy-duty clutch circuit that operates at higher line pressure. Forward gears ("Drive") rely on smaller clutch packs. Without fluid pressure, those friction discs slip, overheat, and glaze or burn off completely—often leaving fine dark sludge rather than chunky metal shavings.
  • Damaged Transmission Pump or Torque Converter: Running dry starves the front pump and torque converter, destroying internal seals and bushings so they can no longer build the hydraulic pressure needed to engage forward gears.
  • Stuck Solenoids or Valve Body Damage: Extreme heat from running dry can warp the valve body or burn out shift solenoids. [1, 2]
  • Improper Fill Procedure: Many modern transmissions (especially sealed units) require a specific temperature window and running-engine check procedure to fill properly. If it is still underfilled by even 1–2 quarts, it may engage Reverse (due to higher reverse pressure) while failing to engage Drive.
2. Why It Still Goes Straight Into Limp Mode
Refilling fluids does not automatically clear persistent fault codes. Additionally, running an engine with roughly 15–20 quarts of oil (nearly 4 times the normal capacity) causes the crankshaft to whip the oil into foam (aeration) and creates massive crankcase pressure, leading to secondary failures: [1, 2]
  • Latched Transmission Control Module (TCM) Codes: If the TCM detected an incorrect gear ratio or solenoid circuit failure, it will keep the vehicle locked in limp mode until the codes are cleared with an OBD-II scanner—or immediately re-trigger limp mode if the forward clutches are physically slipping.
  • Blown Seals & Fouled Sensors: Extreme crankcase pressure from overfilled oil pushes oil past seals and through the PCV system into the intake. This frequently fouls the Mass Airflow (MAF) sensor, throttle body, oxygen sensors, and catalytic converters, any of which will trigger immediate limp mode.
  • Oil-Soaked Wiring Harness: Overfilled oil blowing out of breathers or dipstick tubes can saturate wiring connectors near the transmission or engine block, causing short circuits or communication drops. [1, 2, 3, 4]
These were my biggest concerns honestly. I'm a 'car guy' of the variety that is good at fixing them, its why i specifically went for a 4runner with the 5th gen 'unkillable' engine. Unfortunately, i was a sold a lemon, and the dealership has clearly royally parked up. So what im getting from this, is i effectively need rebuilds of both engine and transmission to at the minimum check for less visible damage.
If dealership oil change, I would push for replacement transmission & engine through them.
i do plan to confront them, i made a video as soon as i saw the damage, before i even started draining anything.
I also, as a note, should have waited until i woke up a bit more before that reply, im NOT the kind of car guy who is good at fixing them, i just enjoy reliable vehicles, and the looks of classic cars.
youngrk
