2015 DRL issue
T4R_S2k
They wont turn on anymore on the drl setting. Ive had the 4runner just shy of a month...it's an sr5 2wd. Any ideas? The high beam works just not the drl. I couldnt find which fuse is related to drl. If i cant solve it i will just take it in.
Thanks in advance
Thanks. I just checked the e-brake it was all the way up. Do you happen to know the location of the fuse? I could not make out the abbrev on the fuse covers :(
There is NO FUSE for DRL on 2014/2015. The fuse is for the individual 9005 lightbulbs, so, if highbeam is working, then it is NOT the fuse.
There is a new(for 2014+) DRL relay, but that part itself is $150+.
Your truck is new, anything like that should be dealt with @ the dealership.
Most likely the relay or loose wiring(rare).
I can post the electrical wiring diagram if you want to debug more, but I still think this should be dealt with by the dealership.
Thanks Jicko i appreciate your helpful info. That's good to know. I will just take it in when my first oil change is due. It's the wife t4r and she can careless but for the fact that i know its suppose to work erks me..
H.Sikina
