2016 SR5 Sleeping Platform 3rd Third Row
DingusGoziña
If you're looking for the most comfortable bedding within your 4Runner, look no further...
This post details how to set up a bed inside your 2016 4Runner SR5 with 3rd Row Option.
I have perused the forums and stumbled upon many sleeping platform builds. Many that caught my eye included:
  1. Toyota 4Runner Forum - Largest 4Runner Forum - View Single Post - What did you do to/in your 5th Gen today?!
  2. DIY Sleeping Platform B uild for the 5th Generation Toyota 4Runner
  3. Anyone have a camping/sleeping setup inside of the 4Runner? - Toyota 4Runner Forum - Largest 4Runner Forum
  4. https://www.toyota-4runner.org/5th-...-cargo-area-level-seats-when-folded-down.html
However, all of these guides lacked the 3rd row option and therefore their middle row seats could fold up. Finally I discovered this post: which detailed how he made a sleeping platform for the 4rd row option on the cheap. His guide specifically mentioned that his goal was to have ready access to utilize the second-row seating. This meant a collapsible and stowable sleeping platform. I have since done this, and taken the measurements necessary so that you don't have to.
Materials
  • 3" Foam $25
  • 1 piece of 1/2" thick Plywood 36" x 42" $20
  • 2 pieces of 1/2" thick Plywood 40" x 26" $20
  • 2 pieces of 1/2" thick Plywood 42" x 21" $20
  • Rubber Floor Mat $30
  • Memory Foam Mattress $75
  • Down Feather Top $125
First I went and picked everything up at Home Depot and Miner's Ace Hardware...
Final Product:
Here I have backed out the 36" x 42" plywood to show the 2 42" x 21" plywood underneath. The two 42" x 21" are placed next to each other with the longest side hanging over the gap between the rear area and the 2nd row seats. The 2 Larger Plywood panels sit on top of these boards, completing the bridge over the gap. The last, large panel sits on top of the two rear panels, leveling everything. Everything is designed to fit inside the rear area with the 2nd row up and in use. NOT Pictured is the 3" memory foam placed underneath the rear plywood panels, it is laying on the grass in the second picture. Check the album to see more...
Hope this helps someone. I chose to go for 1/2" thick plywood and the total cost for everything was less than $300.
Check out this album for the whole set of pictures.
cremebrulady
