2020 roof rack (FJ style), will it fit on previous 5th gens?
Scowling Tuna
Like the title says, I can’t find anything that even alludes to the 2020 having the same mounting layout as previous 5th gens.
Bolt holes are the same 2010 to 2020. Trail and pros have a different bolt/ gasket setup than other trims
It is my understanding that they use a different mounting base but essentially fit into the same spot as any other 5th Gen 4runner. If I am wrong someone please say so as I am planning on getting one in the not to distant future for my 2016 SR5
Here’s the hardware kit I used for my pro rack. It’s actually for the fj. But if you compare the bolts, foam and composite washer, it’s identical.
Your correct [emoji1417]. I have the pro rack on my ‘16 limited. It bolted right up.
ymmv, but not all of us are weekend overlanders and require a large rack. one day if i need one, i'll probably get a gobi stealth. but for now, i rarely use the rack. it was used once transfer my xmas tree :)
But why would you want one of those? They're so little I doubt you can get much use out of them.
Bunkstaff
