265/65R17 vs 265/70R17
:iagree: as far as i know, there are not any 70+ mph posted roads in the US. i check mine all the time by going past the police radar signs on the side of the roads, below & up to 55 its right on, & since i dont exceed posted speed limits, even on the highway, its just not a big deal to me,although it might be for someone who speeds all the time, but if a guys already doing 10 mph over the limit its not that 2 mph difference thats the problem.
I drive a 75 zone all the time. It's just north of GA20 on 985:D And it's about the only time I don't speed:D On the highway I like 75-77 for cruising, I don't feel like I am being a nut but I feel like I am 'getting there'.
Off topic I know... I wanted to bump thread for someone else...
This picture illustrates exactly what I was trying to explain....look at how stuffed the front wheel well looks! To me, this looks more like the stance I'd see on a BMW M3 than the stance that I'd like to see on a 4x4. There is very little clearance in the fender well for that tire. Boy, talk about needed a front lift!
Did this rub at all?
I'm trying to decide between the two. Is there any specific advantage between the two sizes?.
FWIW, if your 4th gen is calibrated like my '05, 265/70/17 will make your mpg display more usable putting actual, calculated mpg very close to display readout.
If you put some weight (luggages, groceries, etc) in the back it should level a bit or more pending how heavy stuff you put back there. I've seen some 2d & 3d gen 4R's on the road who's assses are low.
I've seen a lot of people say that 265/70/17 should have come on the 4Runner from the factory (and a lift but that's another topic). In doing some research on this, why is it that the FJCruiser comes stock with 265/70/17's but the 4Runner doesn't? The Tacoma's come with 265/65/17's like the 4Runner though. I *thought* these three vehicles shared the same axles/differentials/engines (assuming v6) so why would they come with different stock tire sizes? I've checked out the gear ratios too and for a v6 4Runner it seems to be the same 3.73 as the FJCruiser (haven't found the Tacoma's ratio). Any thoughts on this would be great.
Mix of 265/70/17 and 265/65/17
Hi Guys.
I am new to the forum and this is my First 4runner (not first 4x4). I have the 4-th gen. I bought it a few days ago and today I glimpsed at her and something was off. Front tires looked a bit bigger. Fair enough previous owner put 265/70/17 on front leaving 265/65/17 on back.
I know that you shouldn't mix tire sizes, but I would like to hear professional opinion. I need to save some cash for other repairs. So I have a few questions for you:
1. Is it OK to have 265/65/17 and 265/70/17 at the same time? What are the consequences?
2. If it's not a huge deal, Can I put a bigger tire in the back and put 65s in the front. From the first few posts I understood that stock 4gen is a bit cramped on the front anyway.
Have misery on a newly and give some fact if you want.
Thank you guys.
Kochevnik
seltzernator
