265 70 16 tires on a 3 inch lift
pokeyman
I am thinking of putting 265 70 16 tires on my 98 limited with 1.5 inch wheel spacers. Would that look too small on the truck and do anyone have any pictures of 265 70 16 on a 3 inch lift that they can post. Thanks
My buddy Ryan has this same setup, hopefully he sees this and posts a pic. It looks fine but definitely could use more tire.
That's what I'm running and the only time I feel like they're small is when I'm sitting next to someone with 285's (or larger).
<a data-flickr-embed="true" href="https://www.flickr.com/photos/54400273@N03/6204598378/in/dateposted-public/" title="DSC_7271"><img src="https://live.staticflickr.com/6028/6204598378_cf9737a774_b.jpg" width="1024" height="681" alt="DSC_7271"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
I've got 265/70/16 on mine that has about a 2 inch leveling kit, so if you have a 3 inch lift I'd go with 265/75 but it's up to you
Sent from my SM-G973U using Tapatalk
Reviving this thread. I do now see the post.
99, 3 inch OME lift, 1.5 spacers and 265/70/16's.
script>
script>
It's a good tire size IMO. I have yet to really wheel it since I put the spacers on so I'm hoping I wont have any rubbing under flex but we'll see. I'll probably go up a size in the future.
Maybe I'm wrong but I think you are on 265/75's, not 265/70's. There is a noticeable visual difference between them.
I would do 265/75's. It is still pretty conservative and not all that much bigger than factory sizing.
Why would you go through the hassle and expense of lifting it just to run the factory tire size? It’s your money but it seems like it’d be better spent elsewhere if you’re not going to take advantage of being able to run bigger tires.
If that’s a typo and you want to run 265/75-16s, then that’s a different story :)
Yep. I'm rocking 265/75's. Read the initial post wrong.
I've got a 96 on 99 springs running 265/70/16 and there's definitely some room there. I'd love to go to a 285/75 but I haven't confirmed that it won't rub.
Sent from my SM-N950U using Tapatalk
I'm happy with my 265/75s on stock suspension, had to hammer the pinch weld and cut a little off the edge of the front bumper, but they look good IMO.
Looking to do the same.
I just put 265/70r16's duratrac's on my 2001. I want to level it, but have no idea what to buy. (I am new to this) Can ya'll guide me? Just looking to level it a bit. Not a whole 3 inches. Maybe 2 or 2.5?
If you're just wanting to level/baby lift look into 5th gen springs on all 4 corners.
Here's a 1999 on LC 7 Wraps with Tundra TRD Front Springs and a Toytec 3/4 Top Spacer. Total lift was about 3.5 inches in rear, and 3 in the front. Stock 265/70/16's.
2nd Picture on the Street in a 1.5 Daystar Rear Spacer on 99 Talls and the 3/4 Top Plate Spacer in the front. Total lift about 1.5 inches.
This looks great! I wan to do the same. What leveling kit do you have?
I'd like to know the same. I like that look.
I had a lot of driveline issues with the 3" Toytec lift so I'm really contemplating keeping it much more mellow on this one.
But dang....it sure looked good...
