265/70/17 on an 07 Sport is fine right?
Rez90
Just double checking. I am about to replace the tires on my otherwise stock 07 sport.
265/70/17's won't rub correct?
Thanks.
This, "265/70/17 fit stock", placed in the search button will yield amazing results...
-The answer is yes, they'll fit fine.
-BFG K/O's will rub the upper control arm slightly when the steering wheel is cut all of the way. All others fit fine. Where they rub is on a solid, smooth area of the UCA and none have reported damage to tire or UCA from the light rubbing.
-In the unlikely event you do have minor fender-liner rubbing it'll be easily solved by this technique. In the event you hit the 'one-in-a-million' and that doesn't work scroll to the bottom of this page, this WILL work.
Thanks for the response. Picking up at set of Nitto Terra Grapplers in a week or two to replace the stockers.
Yes they will fit. Here's what they looked like on my truck before the lift and wheel spacers.
IMG_2136.jpg~original
IMG_2138.jpg~original
