275/70/17
might go up to 285s though.
Are you lifted or is that stock ride height? (Looks lifted though)
I've had mine on for about 1000 miles so far. I chose white letters out on white paint and I'm glad I did. Some observations:
-They look much better than the stock Dunlops, and even make the stock SR5 wheels look nice IMO. Pictures don't do it justice.
-They aren't louder than the Dunlops, the noise is just a deeper hum.
-The stronger sidewalls give a very slightly harsher ride; nobody but me will ever notice that. The benefit on-road is that you don't have as much lateral sway from thin sidewalls.
-I can't feel that they're noticeably heavier, but my butt gauge can tell a difference in the increased rolling resistance.
-My gas mileage average hasn't changed on my computer yet, though I expect to take a 0.3-0.5 mpg hit.
-There is no rubbing at all.
Love the setup. Sorry for the noob question but what's your overall lift in these photos? 1.75-front and 0.78(20mm)-back?
No tire rub at all on completely stock suspension. I really like the look and the ride is perfectly acceptable. Much like others on here have said, I wish they came in C load rather than only E load to save some weight, and they're naturally a little louder than a good set of highway tread tires. They are a major improvement in both ride and appearance over the stock Dunlops though.Hey [MENTION=107760]salong53[/MENTION] how do you like your KO2 so far? No tire rubbing yet? Is your 4Runner stock no lift?
Hey I am sorry delay. Thanks for liking the setup. In this picture yes this was Billies @ 1.75 setting with all stock coils. Stock rear coils and 2 OME spacers on top. Worked excellent. Was super smooth on trails but I wanted a little stiffer. Im so use to big trucks the corner sway got old. Also loaded with gear and stuff for trips it sagged a lot. Now on OME 884 Coils I think in front. Billies at lowest setting and rear is 1.5 SAW which are a little taller than I like but maybe this summer of constant weight in back will help lower. They drive perfect just a bit stiffer than stock and handle great. I have the spacers from OME sitting in garage if your interested. Worked great for me.
Great thanks for the info. I may go OME coils and the sway 1.5 in the rears as well. I carry about t 50-75 extra pounds of gear constantly but not sure if thats enough to warrant the sways. More research, more debating, more head scratching lol. Thx again.
Perfect setup. You won't be dissapointed and if you have at least that on all the time it won't seem to bad. Ride is perfect.Summer time I have my bicycle rack on 99% of the time and then some bike gear, and bike.... say 90 lbs or so total with rack and it doesn't really change much but maybe somewhat smoother in rear/sagged a hair closer to level (being higher rake empty). Just put truck through a real rock garden stretch of trails yesterday seems to be smoother than every and actually got the rear down a bit.
Maybe all in my head but install and find a nice spot to flex rear each side a few times or get collapsed. Seems to feel better (mental games im sure)
Sorry last question. On your prior setup (1.75 Billes + stock coils + 20mm rear spacers) - how was your on-road drive quality - generally speaking?
I know you mentioned some sway in the corners but I have to assume you had a better-than-stock on-road ride (given the billes)?
I'm doing about 5% off-roading so I want an optimal on-road setup (and save $$ if I can)...
Thanks again man,
FR911
are you guys getting the same size for the spare tire?
I have the 275/70/17 but didn't order the extra one for the spare yet.
