2wd leveling kit for BFG All Terrains
808Runna
Im putting on 265/75r16 BFG AT KO's soon on my '02 Sport Edition. It's 2wd, so wondering if I should do that front daystar spacer lift of 1" or the 2" (cant remember exact heights). also my question is if anyone's done this, did you disconnect the upper control arm to get the shock/coils out?
You shouldn't need a lift at all to run that size tire. But if you do go with it, you shouldn't need to disconnect the upper control arm. Just unbolt the lower ball joints to ge the lower to drop, undo the lower shock bolt, the there top bolts and you're out. Fairly straight forward.
Thanks for the info. As of now the front sits a little lower. I'm pretty picky when it comes to stance of my vehicles. I had the 265/70 BFGs put on last week and they look like pizza cutters to me! I hope the 265/75s fill the wheel wells better...
Rialm
