2wd vs 4wd with elocker drum brakes
95yotarunner619
i have a 2wd and recently bought complete elocker rear end. im replacing bearings, seals and brakes. i recently replaced all brake hardware and shoes on my 2wd axle. now my question is will the shoes and hardware from my 2wd fit onto the elocker rearend. if you are confused about my question let me know.
thanks for the help in advance:thumb:
ABS and non-ABS Axel housings are different where the axels attach at the ends of the housing. This prevents a non-ABS Axel from creating a proper seal within an ABS housing and vice versa. You can get a special non OEM seal that will do the job though.
They Are Both Abs So There Is No Problem There. Thanks for the help. Just didn't want to buy all new brakes and have them both be identical.
TerryNap61
