3.0 rebuild with a few mods.
Eacook1
3.0 rebuild with Dyno results
Added dyno print out 7-5-16
I blew a head gasket last October. After much research I decided to rebuild and add a few goodies. So far I am really happy with it.
I did kind of a photo documentary post on yota tech if your interested.
Eacook's 93 4runner 3vze rebuild - YotaTech Forums
I will dyno it eventually. I need to get some more miles on it though. My engine builder told me to wait until I get 10k miles on it.
It would be cool to find someone with a completely stock engine with the same gearing and what not to go do a dyno run with me. Then we could make a direct comparison on the same dyno with the same conditions.
Re: 3.0 rebuild with a few mods
Hi Eacook1,
May I ask which head gasket you decided to use?
I'm also in the process of rebuilding my 3.0 after a blown head gasket, and I'm at the point of procuring head gaskets.
I would appreciate receiving any input you might have on this.
Thanks and regards,
SanDiego91T4R
Hi Eacook1,
Thanks and regards,
SanDiego91T4R
I got them from lcengineering They sell a multi-layer steel (MLS) head gasket. The way I understand it is you really need to surface the heads and deck the block with this gasket as it needs a very smooth surface to work properly.
I made a very similar decision just a few months ago. My motor spun the main bearing and I went with a rebuilt motor. Added multi hole injectors and thorley headers. Couldn't be happier with the choice. I had tossed the egr valve a few months prior and the catalytic converter was tossed when the rebuilt motor went in.
Nice moto man
Good looking build. Awesome part prep. It's almost a shame to build these so pretty, since i can't see shit on mine now that it's installed. (btw I was looking at a 95 Tacoma(?) with a 3.4 the other day, and was amazed by how much room there was, almost enough to climb in and pull the hood closed to work on it! in comparison to this 4runner which I can barely fit a fist in anywhere under hood now that it's done.
Hey, what happened to the yellow chrome for instance on the waterpipe?
Where and how did you get your metal cleaning accomplished?
Looks like you Polish those things somewhat?
I'm going to be a Cali soon, very North of you, but not impossible to try a head to head, although I got nice sluggy 4.88 gears.
I just finished a '95 3.0 , bored first over / balanced, 004 off the decks,
I think I got the meh Pistons from panengine (SCREW THOSE LOUTS avoid avoid avoid more on that later),
New casting heads from Odessa circa a couple years ago, not overjoyed with the valves they put in , but cams looked freshened, and I regapped the valves somewhat conservatively, Center spec or looser.
extremely mild porting (mostly taking out mold-parting cast lines); it didn't look worth going much further due to the insanely long & convoluted upper intakeS which is probably the limiting factor in this engine.
Did you happen to check flow on the manifold? You have to be careful when placing the lower intake manifold in the valley, because it's fairly easy to shift it a few 010" which may put break/discontinuity (" finger nail" obstruction) on the induction path, at the head/ intake parting line, which may kill flow.
Felpro latest head gaskets were good enough for me; you are right, surface finish is according to gasket type, some do better with smooth finishes to accommodate some movement, other types do better with a good hard bite from higher Ra R_\text{a}... Most decent gaskets will come with a recommendation
I did a fairly aggressive first 30~50 mile break-in then a quick oil change; I like the idea that high cylinder pressures help seat rings better, so I got up to 4 ~ 4.5K rpm runs (using lower gears to keep the RPMs up without becoming popo bait on the speed) & even some hill hauls , after just a few preliminary lower RPM runs, using non-ethanol.
Knock wood, no drips or funny noises a couple days into it.
I ordered a new one and that is the way it came. As for cleaning, the machine shop did all that, along with the paint.
Yes, he ported and flowed the manifold. If you look at the bottom of the flow sheet he says it flows 91% of what the heads will flow.
thanks mon.
what make / model EX pipes are those ?
wutdija pay ?
Have you installed them already ? did you install before or after engine-in ? I installed my iron manifs before I even torqued the head ( although both surfaces were fresh / flat, which is the main gotcha) and was later much happy to not have to work in that tight area.
Are those weld up joints or designed to slip together & clamp?
I am wondering how much hell it was to get the head pipes on ...
They are Doug Thorley. The run about $630. I didn't install them myself. The shop that pulled the motor for me did. He said they weren't too bad. He put them on after the engine went in but before all the accessories and intake plenum went back on.
hey Eacook1, Thanks for posting photos of your motor rebuild. They did great work. Might you post their name? When the time comes, I'd like to ship my motor to them and tell them to rebuild it just like they did yours. Thanks
Unfortunately for everyone else he doesn't do any work for people he doesn't some how know. I know him from when he built a race motor for me some twenty years ago when he and his dad had a speed shop. Now he is a one man show that works out of his garage.
2001ATL
