3 inch lift with 265/75/16
Jaketino
Like the title says, can I see some pictures of rigs with 3 inches of lift while still running 265/75/16s? And can you say what lift your running? I've been saving for a lift for a long time now but I wasn't sure if I needed to get bigger tires after the lift or not.
My lift is a mixed bag of Toytec and Sonoran Steel parts. Please check my signature for details. Here is a pic with 265/75/16 tires. image.jpg
Toytec/eibach springs up front with tundra bilsteins on lowest perch, land cruiser 8.something wrap springs in the rear, 265/75/16 Hankook Dynapros
best_campsite_zpscbcb8340.jpg~original
side_zpsf129a857.jpg~original
Some old pics of mine fit what you are looking for. I liked this set up.
265/75R16 Duratracs with 2.5/3 inch lift coming from OME 881s in front and OME 890s in the back.
I'm running a 3" lift on 265/75's
for those of you running Duratracs, are you guys using spacers or is it because the FJ80 wheels are different backspacing/offset? the reason i ask is because i have 265/75/16 and it doesn't seem as wide...but then again I'm still running on stock 5 stars
Yep. The FJ80 wheels have a different backspacing, which will push the wheel out a bit.
I need to bring the front up a little, but here's what it looks like with the set of 265/75/R16 that I roll on with the SS 1.2 Rebuildable
EnviroHokie
