#3 misfire and have done most under the sun
96-Runner
replaced injector gaskets
swap injectors
new coil pack swapped that around also
new plugs n wires
im out of options as to what it could be
Maybe new coils in general ?
Are the plugs dual grounded ? What brand? What brand wires ? Do you have correct firing order ?
Do a compression test on all cylinders !
Are you loosing any coolant ?
i have the napa sparkplug wires so i believe nothing special as far as dual ground.
coolant stays steady no flux.
firin order is matched and nothing has been swapped as i got the misfire 2 stop for a period of time and returned
havent done a compression test have no knock or coolant/oil variance
A compression test, cooling system pressure check, and a check under the valve cover should tell you whats wrong. Unless its an electrical problem.
just got new tps in and that has made cel light off. still have ever so slight lag time 2 time but hardly noticeable.
AndiGarage
