30,000 service/Special operating conditions
One thing about Toyota's Maintenance schedule, is that is very open to interpretation. Sure they do actually tell you to change the oil and some other stuff, but mostly they just say to "Inspect" the fluid, which basically translates into "Make Sure It Isn't Leaking and is at the proper level". Toyota's idea of Inspecting Your Transmission Fluid, is to just check for leaks....
Nowhere in the maintenance guide do they ever tell you to replace the PS fluid, or Bleed the Breaks, change diff fluid, change the PVC Valve, ect.
Sure you can "Inspect" your diff fluid, by making sure it is at the proper level, and not leaking, but since you can't really go by fluid color, how do you know when it is bad, unless you draw a sample and send it to a lab for fluid analysis? Toyota's Maintenance guide tells you to "Inspect" your F&R Diff Oil every 30k miles, but they never actually tell you to change it.
Alot of things you just kind of have to guess on/use your best judgment, and do what makes you feel comfortable.
I just follow the normal Maintenance plan listed in Toyota's Maintenance guide. I replace what they tell me to when they me to, and use my best judgment for the Inspection Piece.
I just performed my 30k myself, and have performed all previous maintenance. Here is what I have done so far, and I feel that if anything, I have errored on the side of caution:
5k - Pretend to Rotate tires (Like I really want to preserve the life of those crappy stockers...)
10k - Oil Change, Tire Rotation, Lubed Driveshafts, "Inspect and Adjust All Fluid Levels"
15k - Replaced Front & Rear Diff Fluid with Amsoil 75w-90 SVG (Rated for 50k mi service intervals), Inspected Transfer Case Fluid
*Front Diff Fluid looked ok, but rear was pretty nasty so I decided to change
20k - Oil Change, tire rotation, Lubed Driveshafts, "Inspect and Adjust All Fluid Levels"
25k - Nothing
30k - Oil Change, Tire Rotation, Lube Driveshafts, "Inspect and Adjust All Fluid Levels", Replaced Engine & Cabin Air Filter, Inspected F&R Diff Fluid (Looks new), Inspected Transfer Case Fluid (Looks New Still)
All of the maintenance tasks so are super easy to do at home, and if you can change your Engine Oil, you can do the others as well. Especially with all of the detailed DIY writeup on this site. No need to throw money at a dealership to half-ass perform maintenance, some of which you don't even need.
This early, not alot is needed, but it will be interesting down the road when you really need to "Guess" if your "Only inspected thus far" fluid/wear parts need to be replaced, since it is never specified in the maintenance guide, and dealership maintenance recommendations can't be trusted.
Seriously though, I would like to know how often you should replace your PS Fluid...
The kicker is still the oil. I haven't received word back on the actual changes to the 5th gen motors to constitute 0w20 oil. It pains me to see that water go into my crankcase.
Cabin air...
The best prices I have found for cabin air filters is on Amazon. I was able to put it on automatic delivery for every six months. It just takes a few minutes to swap out and really makes a difference.
I don't see it tied to the drop shipment program.
Coupon: $2.00 off FRAM Fresh Breeze Air Filter
It's called subscribe and save. Use the link I posted above and look to the right...
$13.99 delivered, or add it to your sub and save account and get 15% off...
Amazon.com: FRAM CF10285 Fresh Breeze Cabin Air Filter: Automotive
$11.89 with free shipping. (for Prime members)
The more things you have auto shipped monthly the bigger discount you get on the prices.
I think it is something along the lines of 1-4 items is 5% off, 5-10 items is 15% off, etc.
How much offroad driving in dusty conditions does it take to warrant changing the diffs and transfer case fluids at 30K?
Does anyone think changing the brake fluid at 30K is warranted if you offroad in dusty conditions?
Toyota says to "Tighten nuts and bolts on chassis and body." at 30K. Is there a diagram that shows the location of the nuts and bolts that need tightening. How much should you expect a dealer to charge for that?
off road use will require the diff's and transfer case fluid replacing 30K miles ..
also drive shaft greasing every 10K miles.
brake fluid should not be a problem unless it is 10 yrs old . a very sealed system.
air filters eng/cabin need checking .. if looking dirty replace..
I did replace my OEM cabin filter not to my liking used a carbon air filter had thicker filtration material no dust got into the vehicle.. I was in a SWFL construction area all that beach sand dust got passed that OEM filter.
injector servicing can damage the injectors IMO NO !
off road do the transmission fluid @60K miles.. or do the fluid checks also @15k-20K miles if looking odd change it ..
Brake fluid every 10 years? Jeeze, these things are known to have sticky pistons in the calipers due to corrosion on the piston and walls. Most likely from old brake fluid that collected moisture. I do brake fluid every 2-3 years, super easy to do, don't even have to remove wheels if you just lay under truck to do.
The cabin and engine air are super easy to change and the fram ones at walmart are cheap and good quality. Air filter for the engine is super important with a long oil change interval
Thank you for the input. Anyone know the answers to these?
1. How much offroad driving in dusty conditions does it take to warrant changing the diffs and transfer case fluids at 30K?
2. Toyota says to "Tighten nuts and bolts on chassis and body." at 30K. Is there a diagram that shows the location of the nuts and bolts that need tightening. How much should you expect a dealer to charge for that?
I can't find a diagram showing the nuts and bolts that Toyota says to tighten. Is it in a special service manual?
044runner4
