33's on a 4th gen sport
So currently Im running the toytec 3" spacer lift with 265/70/17 tires and spidertrax wheel spacers. I had to trim the front of the wheel well splash guard as well as remove the front mud flaps to stop the rubbing. How can I fit 33's on my 4th gen? I really want to step up to 285/70/17. The 265's didn't rub at all before the lift and spacers.
If you don't change your spacer lift, the only way to fit 285/70's is to trim more. You could possibly run 255/80's (33") an inch narrower, maybe fit with no trim.
Your spidertrax is what made the 265's rub, you will need some wheel spacer for 285's if stock wheels.
Change your spacer lift to a coil lift would probably be best for rub and maybe ride as well
The wheels aren't stock but I'm unsure of the back spacing and offset of the wheels that are on there. I didn't put them on so I'm unsure.
Well the wheels have the size and offset stamped on the back of a spoke or wheel somewhere, what brand? Model? Will only be a few options. If you have quiet a bit of backspacing and added spacers, no wonder it rubbed. Can possibly take them off and be good.
Post a pic or info on wheels.
I'm running 285/70r17's on mine right now. You need a body mount chop and some significant trimming and hammering in there to get them to fit well.
H.Sikina
