I guess I can post here haha. Been running 35's for about 1.5 years now. Dont know if it will be much help to anyone since I have a lot of stuff most do not have on their trucks, but here it goes.
Tires:
Ive had both Toyo Open Country MT's and BFG KO2's in a 35x12.5r17. Rim size is 17x9 with about 4" of backspacing. Running a 1.25" spacer in the rear
Suspension:
Front: Custom +4.5" each side long travel kit
Probably about 3" higher than stock, although its hard to tell at this point
Rear: OME 895 springs with Icon Aluminum 2.0 shocks
(Soon to be leaf spring swapped with Deaver F67's and most likely 12" shackles with 12" or 14" stroke shocks, axle will be moved back about 3/4" to help with clearance)
1.5" Body lift
No bumpstop extension, front or rear
Body Mods:
Body mount chopped
Trimmed Fiberwerx front fenders
Trimmed ~1" from the rear bumper in fender well area
Front tube bumper I built
Fit:
Clears lock to lock full compression in the front
Slight rub in rear on door in fenderwell, but not much can be done about that
Other Mods:
Regeared front and rear with Yukon 4.88's, solid spacer in the rear
CVJ 4130 front axle shafts running OEM outer CV's
