3rd Gen Sun Visor Clips
yeowzer
Does anybody know what that part number is for the clips that hold the sun visors when they are flipped up?
Kevin
I've never seen a clip that holds the visor in the flipped up position, they always just stay wherever you put it.
Do you mean the clip that holds the visor in the across the windshield position? If so then the part number varies slightly depending on what color interior you have. It's called a Holder, Visor
74348-22020-B4 (bluish-grey)
74348-22020-B8 (moon mist)
74348-22020-B9 (charcoal)
74348-22020-E1 (oak)
At the risk of making myself sound like an idiot, how do you remove this clip? Obviously, I removed the clearly visible screw, but it is still snug. I don't want to break it trying jerk out it out though. Once you remove the screw, how the hell do you get this thing out? Thanks in advance for any guidance.
Short answer, you just gotta wiggle it back and forth while pulling it out, and work it out of the hole its in.
The reason for this is the screw spreads a couple of tabs that hold the plastic part in a hole. Think of it kinda like a dry-wall anchor, if that makes sense. Obviously after time they get less flexible and therefore harder to get out. Hope this helps.
Jesse1
