Hi,
I am all the way into a head gasket replacement. A little background before I begin...I bought a 93 4funner for 500 bucks. It was missing a back window and was blowing smoke (smoke appeared as he was driving the twelve miles home from the auction where he purchased the truck). So the previous owner tried to do the head gasket repair on his own. the result is pictured below
I cut off the timing belt as it was shredded. the fan & shroud were out along with some other misselaneous items.
My plan is to pick up where he left off and repair the head gasket. complete with the following repairs: machine the head, replace the busted fuel injector, toyota factory gasket and seal set, idler pulleys, New head bolts from engnblder.com, new timing belt from yota and new knock sensor.
the water pump looks and feels like its in good shape.
so, this brings me to my question. I have read a ton of posts and I am having a hard time finding a few little bits of information. I have the chiltons and the free online manuals.
1. what is supposed to fill the threaded hole pictured here?
it is right behind the fuel rail on the passenger side and is part of the water bypass outlet. there was nothing there when I bought the truck.
2. does anyone see any red flags with the cylinder or block pictured here?
or here?
I have never been this deep in an engine before so I dont know what to look for.
3. is there a rule of thumb that I could follow regarding sealant and gasket builders for the various connections? I see blue around the water pump, orange around the various air inlets and silver on the old head gasket. Just look for a bit of clarity to simplify that decision making process?
4. there seems to be quite a lot of oil around the bottom the bell housing. Is it possible that this vehicle did not blow a head gasket but instead needs a rear main seal?
thanks for you advice.
