4 Runner stuck in park
T4Rscott
hi all,
I went to leave work and the the 4 Runner would not shift out of park. I used the override to get home. Once home I realized I did not have any brake lights. Am I correct to think it's the brake switch located above the pedal? Any info would be great.
i had a similar problem and changing the transmission fluid solved the problem. I've heard of other 4 runners rear breaks sticking as well. the burnt trail lights sound like a different issue.
I just went through this. Swapped out the brake light fuse. The next day, it blew again. And the turn signal fuse went as well. Then I realized the problem - my towing harness was pinched between the rear bumper and the hitch. It shorted both the brake and turn signal circuits. Check there first. Usually, fuses don't blow unless there is a short to ground in the circuit.
