4 wheel drive and turning sharp problem?????
a better definition
1. "clicking" while turning hard
2. drifting while driving:driving:
both symptoms can be attributed to a worn pitman arm.
This is just a sharing experience form a fellow 4runner not necessarily a definitive diagnose fro your vehicle.
O ok how do i check to see if that is bad?
Lets clarify, when does the clicking occur? just when your in 4 wheel drive or all the time? only on corners? left corners or right corners? Clicking on corners can be almost any steering component or a bad cv joint. Constant clicking on a corner would be a cv joint. If it clicks once, like a pop, its a steering component. Id recommend getting a front end check to properly diagnose the issue, its hard to the untrained eye to tell if its a pitman arm, tierod, or steering rack thats causing the issue. hell could be a loose bushing or a loose shifting part
Ok it only does it every once in a while not often. It is a clicking noise, and it only does it when i am in my driveway turning around and the wheel is turned all the way to EITHER side. I'm going to check it out friday since its going to be warm if i find anything i'll fix it if i don't i'm going to have it checked over by a mechanic.
... It is a clicking noise, and it only does it when i am in my driveway turning around and the wheel is turned all the way to EITHER side. c.
That could be from the steering stops. The plastic caps on them could be worn out or gone, a common problem.
