450lb Tongue weight need distribution hitch?
bass-o-matic
I'm towing a travel trailer with a 2002 3rd gen 2wd. The tongue weight is pretty at the limit around 450.
The rear drops a good inch and a half and so the front look higher...
I wonder if I need a weight distribution hitch? Surely 450 lbs on the back is not enough to pop the front wheels up so much they would be an issue?
I mean I've driven it a thousand miles probably with no problems. But you know... never in wet conditions.
Thoughts?
I have the e2 wdh which made the rear sag quiet a bit. it tracked fine with the popup which was only 2500 lbs but I added airbags in the back from amazon for like 90 bucks and leveled it and it was way better.Since then I vé pulled motorbike trailer that was at almost 4500 lbs if not more but I also added a tekonsha p3 for brakes and had no issues.
Laredotx
