4R 1988 blinkers/turning lights don't work
SomeDay
This is the thing: the emergency/hazard lights work perfectly, but my blinkers/turning don't. Please, can you help me to solve this problem.
P.S. I don't have books or documentation yet, I just ordered a couple of manuals to maintain/repair my 4R, but I'll get them in a couple of weeks.
Since the hazards and turn signals share the same flasher module it's not that. The leaves 2 things, the rocker switch used to turn the hazards on/off (also make sure it's not stuck in the middle ) or the turn signal switch (what Toyota calls the combination switch ).
This's going to take me time, I'll follow your suggestions and I'll post the result.
Thanks a lot.
Congrats on finding a first-gen!
Yes, most likely the combo switch/stalk.
Here's how the turn signals work.
O.P.,
Start by checking if you have 12Volts on B1 pin (Green and Blue wire) of turn signal switch/stalk.
If not trace the wire back to the Engine Fuse.
Then, let us know.
O.P.,
Then, let us know.
A lot of valuable info in that thread, I appreciate it a lot, thank you!
I'm going to follow your advice, I'm going to get a multi-meter :) I don't have one, it looks like the one you recommend in your signature's good.
I'll be over it for a few days, and I'll post the result.
Thank you very much!
I downloaded a FSM this morning, and I wanted to upload a page which can be a quick reference if somebody's dealing with the same problem than me:
All the blinkers stopped working, on my 2000 SR5 recently.
- my mechanic pushed the hazard flasher button, a few times
- this dislodged some dust-dirt or something, on the wiring contacts of the switch
- and my blinkers, started working normal again
Not saying this is OP's problem - but can't rule it out.
I'll take a look at it also.
Thank you.
