4runner 1999 4-Cylinder Fog Wiring Harness??
darkparakeet
I checked my 4-runner 1999 and i don't see a plug for fog lights under the hood/bumper. Can someone give me the link so i can get the wiring? or does any fog wiring work. I want to install oem fogs. Thank you
Does your 4runner have the fog light switch already on the stalk?
Nope, I have no switch and no plugs :sad:
OK, do you "plan" on using a factory switch?
Do you have Daytime Running lights?
Also, look at your engine bay fuse block, check if there are 4 wires available in the Fog Relay location, and 2 wires available for the fog lamp fuse?
I don't think there is any one place to go for the wiring. The EWD I have is for an 02, I could make it work. I haven't tried yet but I will. There should be some links you could search for regarding retrofitting the factory switch.
It's a very simple circuit that would be easy to reproduce except for the connectors. But those can be had too.
Philthyphilthy
