My needs for a lift are about what yours are. I do light offroading, mainly for hunting/camping, but wanted something more than the spacer up front. I have 5100s, a rear spacer, and wheels waiting to get installed.
If you are patient and shop deals, you can likely do it cheap. I was able to get the front 5100s (part # 24-196499) for about $150 shipped from Jet.com. If you are a new user, you get a big discount. Not sure if they will be that cheap currently, but it will likely be the cheapest available. I found a rear 1.5" Daystar rear spacer (part # KT09127BK) on ebay for $28 shipped. You can find them for $35 all day. I was quoted $260 for install and alignment. I purchased the Level 8 MK6 wheels at just shy of $500 shipped. I think it was $486 from Discount Tire Direct. However, this included a $100 rebate card through a labor day promotion. So $386 into that. Plus an additional $45 or so for lugs as the stock ones will not work with most aftermarket wheels.
That said, if you are not purchasing new tires, you can likely stay under $1000 without the 5100 rears (part # 33-187174). I will be adding these. I have seen them for around $150 as well. But you could initially just go with the fronts until budget allows for the rears. Just be careful with bumps. I'm putting 275 KO2s on, so that is an added expense for me. With a negative offset, the 265s look fine with a lift as well.
Not sure you'll find everything at those prices, but shouldn't be too too far off. I have known what I wanted for YEARS, just kept waiting. That is part of why I found the deals I did. Ordered the 5100s and spacer in Feb and have just been waiting on wheels. Finally pulled the trigger on those a few weeks back so I am ready. Let me know if I can help with any additional info.
