4th Gen 4Runner (2003-2009) Rock Sliders: Step & Trail Edition specs, fitment, Q&A | Cali Raised LED
Caliraisedled
Official Vendor
4th Gen 4Runner (2003–2009) Rock Sliders: Step & Trail Edition, updated Nov 2026
Jake from Cali Raised LED here. Here's the current info for our 4th gen sliders. Ask fitment questions below.
Fitment
  • 2003–2009 Toyota 4Runner.
  • Fits the Limited and other X-REAS trucks once the X-REAS lines are removed. Not for the Lexus GX470, which has its own slider.
Two styles
  • Step Edition: step-friendly profile, available with or without top plates.
  • Trail Edition: 20-degree, tighter-to-body profile for clearance. No top plates.
Specs
  • 1.75" DOM tubing, .120" wall
  • Full frame plate, front and rear clamping, full gusseting, Grade 8 hardware
  • 100% bolt-on, no drilling or cutting. About 1–2 hours.
  • About 100 lb per set (Step Edition) or 90 lb per set (Trail Edition)
  • Kick-out or no kick-out. Raw steel, powder coat or bedliner.
  • Fabricated in-house in Fort Worth, Texas. Free FedEx Ground to the lower 48.
Links (from $909.99 a pair)
5th & 6th gen sliders: https://www.toyota-4runner.org/threads/266181/ · Step vs Trail: https://www.toyota-4runner.org/threads/277773/
Questions: reply here, call 888-385-5036 or email [email protected].
Options explained
Kick out or no kick out?
Kick out vs no kick out rock sliders
Kick out angles the back of the slider out, in front of the rear tire, so the back of your truck doesn't get pinned on rocks. No kick out runs straight for a clean look. Same price either way.
Which finish should I pick?
Rock slider finishes: raw steel, powder coat, bedliner
Raw steel: bare steel that will rust if left uncoated. Paint or coat it right away. Powder coat: black, ready to bolt on. Bedliner: rugged textured finish with extra grip, offered on the slider and the filler plates.
Do I need filler plates? (Step Edition)
Filler plate vs no filler plate
Filler plates (also called top plates) are optional. They fill in the top of the slider for a flat step with better footing, and come in raw steel, powder coat or bedliner. Skip them for an open tube look.
Popular setup: Kick out, powder coat slider, bedliner filler plates (Step Edition).
2003-2009 Toyota 4Runner Rock Sliders– Cali Raised LED
Fits once the X-REAS lines are removed, including on the Limited.
Protect your 4Runner with the Cali Raised LED Rock Sliders. Made from DOM 1.75" tubing, we don't up charge you for better material or for features like kick outs. Bolt-On sliders come with all the required hardware you need for the install and are installed with zero modification to your vehicle.
Can you get the Filler Plates for the 20 Degree Ones also? Any pics of how they are bolted to Frame? Thanks
Not compatible with X-REAS suspension components.
Protect your 4Runner with the Apex Fabworks Rock Sliders. Made from DOM 1.75" tubing, we don't up charge you for better material or for features like kick outs. Our sliders are made the best way we know how for the best fit and protection standard, no up charge. Bolt-On sliders come with all the required hardware you need for the install and are installed with zero modification to your vehicle.
These should fit fine with all the XREAS components removed right?
youngrk
