4th Gen 4Runner (2003-2009) Rock Sliders: Step & Trail Edition specs, fitment, Q&A | Cali Raised LED
Caliraisedled
Official Vendor
4th Gen 4Runner (2003–2009) Rock Sliders: Step & Trail Edition, updated Nov 2026
Jake from Cali Raised LED here. Here's the current info for our 4th gen sliders. Ask fitment questions below.
Fitment
  • 2003–2009 Toyota 4Runner, KDSS and non-KDSS.
  • Not compatible with X-REAS suspension components, the 4Runner Limited or the Lexus GX.
Two styles
  • Step Edition: step-friendly profile, available with or without top plates.
  • Trail Edition: 20-degree, tighter-to-body profile for clearance. No top plates.
Specs
  • 1.75" DOM tubing, .120" wall
  • Full frame plate, front and rear clamping, full gusseting, Grade 8 hardware
  • 100% bolt-on, no drilling or cutting. About 1.5–2 hours.
  • About 45 lbs per side (90 lbs a pair)
  • Kick-out or no kick-out. Raw, powder coat or bed liner.
  • Fabricated in-house in Fort Worth, Texas. Free FedEx Ground to the lower 48.
Links (from $909.99 a pair)
5th & 6th gen sliders: https://www.toyota-4runner.org/threads/266181/ · Step vs Trail: https://www.toyota-4runner.org/threads/277773/
Questions: reply here, call 888-385-5036 or email [email protected].
2003-2009 Toyota 4Runner Rock Sliders– Cali Raised LED
Not compatible with X-REAS suspension components.
Protect your 4Runner with the Cali Raised LED Rock Sliders. Made from DOM 1.75" tubing, we don't up charge you for better material or for features like kick outs. Our sliders are made the best way we know how for the best fit and protection standard, no up charge. Bolt-On sliders come with all the required hardware you need for the install and are installed with zero modification to your vehicle.
Can you get the Filler Plates for the 20 Degree Ones also? Any pics of how they are bolted to Frame? Thanks
Protect your 4Runner with the Apex Fabworks Rock Sliders. Made from DOM 1.75" tubing, we don't up charge you for better material or for features like kick outs. Our sliders are made the best way we know how for the best fit and protection standard, no up charge. Bolt-On sliders come with all the required hardware you need for the install and are installed with zero modification to your vehicle.
These should fit fine with all the XREAS components removed right?
lindwlson982
