4RunnerFan
I searched the forum without success, so please forgive me if I missed it.
It appears there is a lot of interest in converting standard turn signal bulbs to LEDs, but frustration mounts when the signals end up hyper flashing. I've read one can buy resisters for each bulb circuit, but the easiest solution appears to be replacing the flasher behind the fuse panel under the driver's side of the dashboard.
Unfortunately, it appears that buyers of said flasher end up with the wrong one being shipped to them and they have no idea where to get the correct one.
After all these years, my question is simply if any of you have been successful in replacing your flasher with a compatible module that works with LED turn signals (if so, where did you find it and which one is it?); and if it would make a difference if the vehicle is equipped with daytime running lights.
