5-1/4 Rear Speaker Install - How To
snowninja
My Alpine SPS-510's showed up today and I decided to install using the existing speaker 4" speaker mounts. i know there is a kit that is sold which makes this easier but i had the time and the tools so wanted to use what i had. the install worked out great and no issues with the window hitting the speaker magnet. they roll down all the way!
Here are the parts/tools i used:
heat gun
putty knife
japanese pull saw
dremel with cutting bit
soldering iron
RV window gasket seal
Parma Servo tape (double sided super sticky stuff for RC applications)
first thing was to remove the old speakers from the plastic mount. they are glued in so i used the heat gun to warm up the glue and a putty knife to free them from the mount.
then i took the japanese saw and removed the riser on the mount:
0202161513.jpg~original
the hole is still too small for the speaker housing so i used the dremel to make it bigger. i lined the template up and set it so the bottom would not need to be cut since too much plastic would have been removed. i wanted to save the original wiring connector so i had to remove that for now, the cut could have been cleaner and slightly smaller but the RV gasket filled the gap nicely.
0202161520.jpg~original
after putting the RV window gasket on i laid down the speaker template so i could drill the holes for the mounting ear screws. the speaker wire connectors themselves are oriented towards the top of the door.
0202161530.jpg~original
0202161530a.jpg~original
speaker fit nicely, just make sure the ears are not in the way of the mounting plate holes
0202161533.jpg~original
the speaker screws were a little long so i drilled out relief for them on the door:
holes.jpg~original
since the old gasket was a little thin and some tore off i rolled up some more RV gasket and stuck it on the door following the original pattern. this should keep a nice tight fit for a long time and seal it off nicely.
0202161601.jpg~original
i then cut off the old wires and used my soldering iron to remove the wire from the posts of the harness and soldered up the new wires. i used the RC servo tape to attach the harness back to the mounting plate.
0202161603.jpg~original
ran a quick sound test and all was well so i put it all back together.
I did similar. I took a bunch of relief cuts out of the original plate for the speaker webbing. This allowed it to drop down and sit flush against the face of the mounting plate.
Then I clocked the speaker flanges so they missed the original holes, and ran long screws/nut's with a little foam backing behind them. Work's great, clears the window when it rolls down and fit's behind the door panel without adding profile height.
Clean install. I just cutting things apparently :)
Nice, glad your window clears. I actually am doing 160 sq ft of sound deadening in my runner as we speak. I will take a couple pics of my ghetto-install for anyone concerned with a deeper mounting depth. I run the 5 1/4 type errrrrr as well. Excellent speaker's with some power sent to them. I run them front and rear, best speakers for the money I've ever used.
Nice. Would like to see that. I want to do fresh carpet so would likely do deadnening as well.
have the ktp445 plugnplay alpine 4x45w amp on order for weekend install, put one in my wifes f350 and it made a huge difference so should wake these alpines up a bit. Too many tweakers around here so I don't plan to put in anything to flashy or easily visible just like some decent sound
Yeah I am deadening the piss out of mine for holding my sound in to avoid unwanted attention. My truck has 3 kill switches and some tricks if anyone got that far. Plus glock owner defense system.
I'm using second skin stuff. I am a huge fan after using it in 2 cars. It works amazingly well, I might have enough left to justify selling (50 Sq ft plus) I'll give you a shout if I do.
DJNutshell
