5 speed tranmission questions
nail bender
i have done a lot of searching and cant find the answers i am looking for. i have a 1995 4runner 4x4 with a 22re and a 5 speed transmission. i need a transmission what else can i get one out of that will bolt right in? i have found specs on line that tells me what transmission came in what, but not what will swap from another toyota model
Not sure whats in your runner but my 94 runner with 22re came with a g58 and Im putting a w56c in it as soon as can get to my buddys shop. Probably this weeked.
Here's a pic of it. I just installed the duals with a gear resuction kit and I put RADesigns "Triple Sticks" on it too.
thank you for the info do the transmissions have a tag on them with the number or a casting number i need to look for to identify the trans?
Might also need the transfer case to go w/ it. Yours may have a chain case. Gear driven trans cases are stronger and you can up grade the low range easier.
You can use a W56 from 85-95 pickups (and first gen runners). So long as they are 22re.
Hold on.
There are 5 different versions of the W56 used in the 85-95 4WDs with a 22RE.
They are not all interchangeable.
93-95 used a W56-E to be specific. But one from a 89-95 will also work.
85-88 will not work unless you get the t-case too.
DexterShaYang
